Ir para o conteúdo principal
Dell Inspiron 15-5547 RAM Replacement
O que você precisa
  1. Dell Inspiron 15-5547 RAM Replacement, RAM: passo 1, imagem 1 %32 Dell Inspiron 15-5547 RAM Replacement, RAM: passo 1, imagem 2 %32
    • Remove the two M2.5 x 5mm screws on the bottom of the laptop with the Phillips #0 screwdriver as shown.
  2. Dell Inspiron 15-5547 RAM Replacement: passo 2, imagem 1 %32 Dell Inspiron 15-5547 RAM Replacement: passo 2, imagem 2 %32
    • Use the Jimmy to pry off the back cover of the laptop.
    • Carefully lift and remove the back cover of the laptop.
  3. Dell Inspiron 15-5547 RAM Replacement: passo 3, imagem 1 %32 Dell Inspiron 15-5547 RAM Replacement: passo 3, imagem 2 %32 Dell Inspiron 15-5547 RAM Replacement: passo 3, imagem 3 %32
    • The RAM components of the laptop can be found in the following locations.
    • Pull the two side brackets of the bottom RAM component horizontally. This will free the component.
    • Lift and remove the RAM component from its location.
    • Be careful with the RAM components as they are fragile.
  4. Dell Inspiron 15-5547 RAM Replacement: passo 4, imagem 1 %32 Dell Inspiron 15-5547 RAM Replacement: passo 4, imagem 2 %32
    • Repeat the previous steps for the top RAM slot.
    • Apply slight pressure onto the RAM to lock it in during the reassembly.
Conclusão
Keegan Tucker
Membro desde: 05/22/19
256 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G3, Harley Summer 2019 Membro de IUPUI, Team S1-G3, Harley Summer 2019
IUPUI-HARLEY-SU19S1G3
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 843
