Ir para o conteúdo principal
Dell Inspiron 15-5547 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
    • Use the Jimmy to pry and detach the keyboard from the laptop at the following locations.
    • Lift the keyboard from the top and gently detach it from the bottom end.
    • Be careful not to pull too quickly in order to avoid damage to the keyboard connector ribbon cables.
  2. Dell Inspiron 15-5547 Keyboard Replacement: passo 2, imagem 1 %32 Dell Inspiron 15-5547 Keyboard Replacement: passo 2, imagem 2 %32
    • Detach the smaller ribbon cable from the laptop connector base by gently pulling upward on the connector base. This will free the ribbon cable.
    • Detach the larger ribbon cable from the laptop connector base in the same manner as the first. This will completely detach the keyboard from the laptop.
    • Be careful when detaching and removing the ribbon cables so as not to tear or damage them.
Conclusão
4 outras pessoas executaram este guia.
Faiq Huzir
Membro desde: 05/22/19
121 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G3, Harley Summer 2019 Membro de IUPUI, Team S1-G3, Harley Summer 2019
IUPUI-HARLEY-SU19S1G3
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 838
