Ir para o conteúdo principal
Dell Inspiron 15-5547 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 15-5547 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Flip the laptop on its top so that the back is facing up as seen in the picture.
    • Using a Phillips #0 screwdriver, remove the two screws.
  2. Dell Inspiron 15-5547 Hard Drive Replacement: passo 2, imagem 1 %32
    • Using an iFixit Opening Tool, pry open the back panel through the small notch.
  3. Dell Inspiron 15-5547 Hard Drive Replacement: passo 3, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the four screws securing the hard drive.
  4. Dell Inspiron 15-5547 Hard Drive Replacement: passo 4, imagem 1 %32
    • Lift the hard drive out of the dock and unplug from the motherboard.
    • Be careful so as to not damage the cable.
  5. Dell Inspiron 15-5547 Hard Drive Replacement: passo 5, imagem 1 %32
    • Using a Phillips #0 screwdriver, unscrew the four screws located on the side of the chassis to free the hard drive from the bracket.
    • Remove the hard drive from the bracket.
Conclusão
Nicholas Nafziger
Membro desde: 11/04/19
266 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G2, Harley Fall 2019 Membro de IUPUI, Team S1-G2, Harley Fall 2019
IUPUI-HARLEY-F19S1G2
3 Membros
Autoria de 2 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 1,378
