Ir para o conteúdo principal
Dell Inspiron 15-3543 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32
    • Turn the device over and open it.
    • You will see 5 notches at the top of the keyboard.
    • Stick the end of the metal spudger between each of these notches to pry the keyboard up. Once you hear a pop sound, stop and move onto the next notch.
  2. Dell Inspiron 15-3543 Keyboard Replacement: passo 2, imagem 1 %32 Dell Inspiron 15-3543 Keyboard Replacement: passo 2, imagem 2 %32
    • Once all five notches at the top of the keyboard are loosened, begin pulling it up from the top.
    • Pull the keyboard up slowly so you don't tear the ribbon cable out or damage it.
  3. Dell Inspiron 15-3543 Keyboard Replacement: passo 3, imagem 1 %32 Dell Inspiron 15-3543 Keyboard Replacement: passo 3, imagem 2 %32
    • To remove the ribbon cable, use the metal spudger tool to pop the ribbon cable lock up.
    • After popping up the ribbon cable lock, you can pull the ribbon cable out.
Conclusão
Um comentário
Thanks. Could you please suggest a recommended replacement keyboard? I didn't find any branded replacement item in Amazon.
Arun Prasad - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 35
Ao todo: 1,197
