Ir para o conteúdo principal
Dell Inspiron 15-3542 LCD Screen Replacement
O que você precisa
  1. Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32 Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: passo 1, imagem 3 %32
    • Power off the laptop.
    • Flip the laptop over so the bottom is facing up.
    • Slide the right button to the unlock symbol.
    • Slide the left button to the other unlock symbol.
    • While holding the left button, use your right finger to raise the battery up from the laptop.
  2. Dell Inspiron 15-3542 LCD Screen Replacement: passo 2, imagem 1 %32 Dell Inspiron 15-3542 LCD Screen Replacement: passo 2, imagem 2 %32 Dell Inspiron 15-3542 LCD Screen Replacement: passo 2, imagem 3 %32
    • Flip the laptop over so the top is facing up and open the laptop.
    • Using both hands, unsnap the tabs around the perimeter of the bezel and remove it from the laptop.
  3. Dell Inspiron 15-3542 LCD Screen Replacement: passo 3, imagem 1 %32 Dell Inspiron 15-3542 LCD Screen Replacement: passo 3, imagem 2 %32 Dell Inspiron 15-3542 LCD Screen Replacement: passo 3, imagem 3 %32
    • Remove the four screws from the corners of the LCD using a Phillips screwdriver.
    • Lift the screen up and place it on the keyboard.
  4. Dell Inspiron 15-3542 LCD Screen Replacement: passo 4, imagem 1 %32 Dell Inspiron 15-3542 LCD Screen Replacement: passo 4, imagem 2 %32 Dell Inspiron 15-3542 LCD Screen Replacement: passo 4, imagem 3 %32
    • Gently peel off the yellow clear tape securing the video connector.
    • Use an opening tool to flip open the video connector bracket.
    • Make sure not to force the video cable when removing it from the connector bracket.
    • Disconnect the cable from the LCD screen and remove the LCD from the laptop.
Conclusão
Najeemdeen Lamidi
Membro desde: 09/19/20
151 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 16
Ao todo: 1,346
