Ir para o conteúdo principal
Dell Inspiron 15-3531 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 15-3531 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 15-3531 Hard Drive Replacement, Battery: passo 1, imagem 2 %32 Dell Inspiron 15-3531 Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Remove the battery to avoid electrical discharge while working with this system.
    • Flip the laptop over.
    • Slide the latches toward the edges to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: passo 2, imagem 1 %32 Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: passo 2, imagem 2 %32 Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: passo 2, imagem 3 %32
    • Loosen the two screws on the access panel using the PH1 head screwdriver.
    • Pry the access panel from the laptop using the spudger.
  3. Dell Inspiron 15-3531 Hard Drive Replacement: passo 3, imagem 1 %32 Dell Inspiron 15-3531 Hard Drive Replacement: passo 3, imagem 2 %32
    • Lift the access panel away from the laptop to reveal the hard drive on the left.
    • Remove the two 8.65 mm screws on the left side of the hard drive using the PH0 head screwdriver.
    • There is a plastic tab beneath the hard drive.
  4. Dell Inspiron 15-3531 Hard Drive Replacement: passo 4, imagem 1 %32 Dell Inspiron 15-3531 Hard Drive Replacement: passo 4, imagem 2 %32 Dell Inspiron 15-3531 Hard Drive Replacement: passo 4, imagem 3 %32
    • Push the hard drive to the left to release it and use the tab to pull it free from the laptop. The hard drive is in a caddy.
    • Remove the two 1.22 mm screws holding the hard drive in the caddy with the PH0 head screwdriver.
Conclusão
Kody Dahlke
Membro desde: 02/15/18
730 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G5, Leahy Spring 2018 Membro de USF Tampa, Team S1-G5, Leahy Spring 2018
USFT-LEAHY-S18S1G5
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 1,030
