Ir para o conteúdo principal
Dell Inspiron 15-3531 Fan Replacement
O que você precisa
  1. Dell Inspiron 15-3531 Fan Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 15-3531 Fan Replacement, Battery: passo 1, imagem 2 %32 Dell Inspiron 15-3531 Fan Replacement, Battery: passo 1, imagem 3 %32
    • Remove the battery to avoid electrical discharge while working with this system.
    • Flip the laptop over.
    • Slide the latches toward the edges to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3531 Fan Replacement, Motherboard: passo 2, imagem 1 %32 Dell Inspiron 15-3531 Fan Replacement, Motherboard: passo 2, imagem 2 %32 Dell Inspiron 15-3531 Fan Replacement, Motherboard: passo 2, imagem 3 %32
    • Loosen the two screws on the access panel using the PH1 head screwdriver.
    • Pry the access panel open with the spudger.
  3. Dell Inspiron 15-3531 Fan Replacement: passo 3, imagem 1 %32 Dell Inspiron 15-3531 Fan Replacement: passo 3, imagem 2 %32 Dell Inspiron 15-3531 Fan Replacement: passo 3, imagem 3 %32
    • Remove the memory card by pulling apart the latches holding it in place.
  4. Dell Inspiron 15-3531 Fan Replacement: passo 4, imagem 1 %32
    • Remove the nine 8.65mm screws holding the backplate to the laptop using the PH0 head screwdriver.
    • Remove the four 1.22 mm screws holding the backplate to the laptop using the PH0 head screwdriver.
  5. Dell Inspiron 15-3531 Fan Replacement: passo 5, imagem 1 %32 Dell Inspiron 15-3531 Fan Replacement: passo 5, imagem 2 %32 Dell Inspiron 15-3531 Fan Replacement: passo 5, imagem 3 %32
    • Depress (push in, not down) the five tabs at the top of the keyboard and the two on each side of the keyboard using a flat head screwdriver.
    • Pry the keyboard from the laptop using the spudger.
    • Be careful when lifting out the keyboard because there is a cable connecting it to the laptop.
  6. Dell Inspiron 15-3531 Fan Replacement: passo 6, imagem 1 %32 Dell Inspiron 15-3531 Fan Replacement: passo 6, imagem 2 %32 Dell Inspiron 15-3531 Fan Replacement: passo 6, imagem 3 %32
    • Lift the latch holding down the cable using a flat head screwdriver.
    • Slide the cable out.
    • This will free the keyboard from the laptop.
  7. Dell Inspiron 15-3531 Fan Replacement: passo 7, imagem 1 %32 Dell Inspiron 15-3531 Fan Replacement: passo 7, imagem 2 %32 Dell Inspiron 15-3531 Fan Replacement: passo 7, imagem 3 %32
    • Disengage both antenna (black and white) cables by lifting them up using the spudger.
    • Unscrew the one 8.65 mm screw holding the wireless card.
    • Remove the wireless card.
  8. Dell Inspiron 15-3531 Fan Replacement: passo 8, imagem 1 %32 Dell Inspiron 15-3531 Fan Replacement: passo 8, imagem 2 %32
    • Lift the locking tab with the spudger and pull the cable form the locking tab.
    • Repeat with the second locking tab.
  9. Dell Inspiron 15-3531 Fan Replacement: passo 9, imagem 1 %32
    • Remove the four 8.65 mm screws underneath the keyboard plate.
    • Remove the three 1.22 mm small screws underneath the keyboard plate.
  10. Dell Inspiron 15-3531 Fan Replacement: passo 10, imagem 1 %32 Dell Inspiron 15-3531 Fan Replacement: passo 10, imagem 2 %32 Dell Inspiron 15-3531 Fan Replacement: passo 10, imagem 3 %32
    • Separate the palmrest from the base of the laptop using the spudger to loosen the palmrest along the edges.
    • Make sure to remove all the screws, especially the inconspicuous 8.65 mm screw next to the hard drive.
  11. Dell Inspiron 15-3531 Fan Replacement: passo 11, imagem 1 %32 Dell Inspiron 15-3531 Fan Replacement: passo 11, imagem 2 %32 Dell Inspiron 15-3531 Fan Replacement: passo 11, imagem 3 %32
    • Remove the cables on the upper left side of the laptop using flat tweezers.
    • Remove the cable from the upper right hand corner.
  12. Dell Inspiron 15-3531 Fan Replacement: passo 12, imagem 1 %32 Dell Inspiron 15-3531 Fan Replacement: passo 12, imagem 2 %32
    • Remove the speaker cable.
    • Remove cable on the right-hand side.
  13. Dell Inspiron 15-3531 Fan Replacement: passo 13, imagem 1 %32
    • Unscrew the one 8.65 mm screw holding the motherboard in place with a PH0 size head screwdriver.
    • Remove the motherboard.
  14. Dell Inspiron 15-3531 Fan Replacement, Fan: passo 14, imagem 1 %32 Dell Inspiron 15-3531 Fan Replacement, Fan: passo 14, imagem 2 %32
    • Turn over the motherboard.
    • Disconnect the fan power cable.
    • Remove the 8.65 mm screw holding the fan casing to the laptop frame using a PH0 head screwdriver.
Conclusão
Uma outra pessoa concluiu este guia.
Kody Dahlke
Membro desde: 02/15/18
730 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G5, Leahy Spring 2018 Membro de USF Tampa, Team S1-G5, Leahy Spring 2018
USFT-LEAHY-S18S1G5
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 737
