Ir para o conteúdo principal
Dell Inspiron 15-3521 Wireless Card Replacement
O que você precisa
  1. Dell Inspiron 15-3521 Wireless Card Replacement, Remove the Battery: passo 1, imagem 1 %32 Dell Inspiron 15-3521 Wireless Card Replacement, Remove the Battery: passo 1, imagem 2 %32 Dell Inspiron 15-3521 Wireless Card Replacement, Remove the Battery: passo 1, imagem 3 %32
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 Wireless Card Replacement, Removing Keyboard: passo 2, imagem 1 %32 Dell Inspiron 15-3521 Wireless Card Replacement, Removing Keyboard: passo 2, imagem 2 %32 Dell Inspiron 15-3521 Wireless Card Replacement, Removing Keyboard: passo 2, imagem 3 %32
    • Flip laptop right side up
    • Using a flat head screwdriver, depress locking tabs holding keyboard into place
    • Using a spudger, pry the keyboard from the laptop, giving room to access with hands.
    • Using hands, remove keyboard completely from laptop body, leaving only the connecting cord that attaches the keyboard to the laptop.
  3. Dell Inspiron 15-3521 Wireless Card Replacement, Disconnecting the Keyboard Cable: passo 3, imagem 1 %32 Dell Inspiron 15-3521 Wireless Card Replacement, Disconnecting the Keyboard Cable: passo 3, imagem 2 %32 Dell Inspiron 15-3521 Wireless Card Replacement, Disconnecting the Keyboard Cable: passo 3, imagem 3 %32
    • To disconnect the keyboard, locate the keyboard cable locking mechanism.
    • Open the locking mechanism by gently pulling up.
    • Slide out the keyboard cable from the interface to separate the keyboard form the laptop.
  4. Dell Inspiron 15-3521 Wireless Card Replacement, Wireless Card Removal: passo 4, imagem 1 %32 Dell Inspiron 15-3521 Wireless Card Replacement, Wireless Card Removal: passo 4, imagem 2 %32 Dell Inspiron 15-3521 Wireless Card Replacement, Wireless Card Removal: passo 4, imagem 3 %32
    • Remove the wireless card cables powering the wireless card
    • Unscrew the wireless card using a PH0 screwdriver.
    • Replace with a new wireless card, reattaching the power cables.
Conclusão
7 outras pessoas executaram este guia.
Andrew Dippre
Membro desde: 10/13/14
2.902 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 3-1, Benson Fall 2014 Membro de Clemson, Team 3-1, Benson Fall 2014
CLEM-BENSON-F14S3G1
4 Membros
Autoria de 9 guias
2 comentários
On an Insperion 15 model 3878, the Wi-Fi adapter wasn't under the keyboard. It was under the inset cover on the bottom.
I reseated the card connection and then Windows could communicate to configure it.
Student4Life - Responder
its wlan is right now 2.4ghz. i want to upgrade it to 5ghz. please suggest a solution!
rohit nair - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 30
Ao todo: 6,174
