Ir para o conteúdo principal
Dell Inspiron 15-3521 RAM Replacement
O que você precisa
  1. Dell Inspiron 15-3521 RAM Replacement, Remove the battery: passo 1, imagem 1 %32 Dell Inspiron 15-3521 RAM Replacement, Remove the battery: passo 1, imagem 2 %32 Dell Inspiron 15-3521 RAM Replacement, Remove the battery: passo 1, imagem 3 %32
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 RAM Replacement, Remove access door: passo 2, imagem 1 %32 Dell Inspiron 15-3521 RAM Replacement, Remove access door: passo 2, imagem 2 %32 Dell Inspiron 15-3521 RAM Replacement, Remove access door: passo 2, imagem 3 %32
    • Loosen the two screws attaching the access door to the laptop body
    • Using a spudger, pry open the access door from the laptop
    • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  3. Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: passo 3, imagem 1 %32 Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: passo 3, imagem 2 %32 Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: passo 3, imagem 3 %32
    • To access the memory cards, push out the latches on the left and right of the memory cards
    • To remove the memory card, pull it out of the tray with the latches still stretched out
    • Insert a new memory card in to the memory card tray, depressing until side latches engage with a click.
Conclusão
7 outras pessoas executaram este guia.
Andrew Dippre
Membro desde: 10/13/14
2.902 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 3-1, Benson Fall 2014 Membro de Clemson, Team 3-1, Benson Fall 2014
CLEM-BENSON-F14S3G1
4 Membros
Autoria de 9 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 25
Ao todo: 6,442
