Ir para o conteúdo principal
Dell Inspiron 15 Optical Drive Replacement
O que você precisa
  1. Dell Inspiron 15 Optical Drive Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 15 Optical Drive Replacement, Battery: passo 1, imagem 2 %32
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 Optical Drive Replacement: passo 2, imagem 1 %32
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 Optical Drive Replacement, Optical Drive: passo 3, imagem 1 %32 Dell Inspiron 15 Optical Drive Replacement, Optical Drive: passo 3, imagem 2 %32
    • Remove the 5mm long Phillips #0 screw that is holding the optical drive in place, as pictured.
    • You can now slide the optical disk drive out of the computer.
    • You do not have to remove the base cover or the Hard Drive if you want to remove just the optical drive.
Conclusão
3 outras pessoas executaram este guia.
Edward Pacheco
Membro desde: 03/06/16
845 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 29
Ao todo: 4,848
