Introdução
In this guide, we will be showing you how to remove and replace the Hard Drive.
Ferramentas
Não são necessárias ferramentas.
Peças
Não são necessárias peças.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn off the computer and turn it over.
  2. Slide the battery lock latch to the unlock position until it clicks into place.
    • Slide the battery lock latch to the unlock position until it clicks into place.
  3. Slide and hold the battery release latch in the unlock position.
    • Slide and hold the battery release latch in the unlock position.
  4. Slide and lift the battery out of the battery bay.
    • Slide and lift the battery out of the battery bay.
  5. Slide the NEW battery into the battery bay until it clicks into place.
    • Slide the NEW battery into the battery bay until it clicks into place.
  6. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  7. Slide the battery lock latch to the lock position.
    • Slide the battery lock latch to the lock position.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  8. Remove the two screws from the computer base.
    • Remove the two screws from the computer base.
  9. Slide the hard drive to the right to disconnect it from the connector on the system board.
    • Slide the hard drive to the right to disconnect it from the connector on the system board.
  10. Lift the hard drive out of the computer base.
    • Lift the hard drive out of the computer base.
  11. Place the NEW hard drive on the computer base.
    • Place the NEW hard drive on the computer base.
  12. Push the hard drive towards the left to connect it to the connector on the system board.
    • Push the hard drive towards the left to connect it to the connector on the system board.
  13. Replace the two screws to the computer base.
    • Replace the two screws to the computer base.
Linha de Chegada
Terrence15
70.274 reputação
442 Guides authored
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
925 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Todo: 81
