Introdução
In this guide, we will be showing you how to remove and replace the Display Assembly.
Peças
Não são necessárias peças.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws from the computer base.
  2. Disconnect the display cable from the connector on the system board.
    • Disconnect the display cable from the connector on the system board.
  3. Make a note of the display cable and Mini-Card antenna cables routing and remove the cables from the routing guides.
    • Make a note of the display cable and Mini-Card antenna cables routing and remove the cables from the routing guides.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. Remove the four screws (two on each side) that secure the display assembly to the computer base.
    • Remove the four screws (two on each side) that secure the display assembly to the computer base.
  6. Lift and remove the display assembly out of the computer base.
    • Lift and remove the display assembly out of the computer base.
  7. Place the NEW display assembly in position and replace the four screws (two on each side) that secure the display assembly to the computer base.
    • Place the NEW display assembly in position and replace the four screws (two on each side) that secure the display assembly to the computer base.
  8. Route the display cable and Mini-Card antenna cables through the routing guides.
    • Route the display cable and Mini-Card antenna cables through the routing guides.
  9. Connect the display cable to the connector on the system board.
    • Connect the display cable to the connector on the system board.
  10. Replace the two screws to the computer base.
    • Replace the two screws to the computer base.
Linha de Chegada
Terrence15
70.274 reputação
442 Guides authored
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
925 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Todo: 30
