Ir para o conteúdo principal
Dell Inspiron 15 M5030 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 15 M5030 Hard Drive Replacement, Remove the Screws: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard drive to the base of the computer.
  2. Dell Inspiron 15 M5030 Hard Drive Replacement, Sliding the Hard Drive: passo 2, imagem 1 %32
    • Slide the hard drive away from the hard-drive connector on the system board.
  3. Dell Inspiron 15 M5030 Hard Drive Replacement, Lifting the Hard Drive: passo 3, imagem 1 %32
    • Lift the hard drive out of the hard-drive bay.
  4. Dell Inspiron 15 M5030 Hard Drive Replacement, Placing the Hard Drive: passo 4, imagem 1 %32
    • Place the NEW hard drive in the hard-drive bay and push the hard drive towards the connector until it is fully seated.
  5. Dell Inspiron 15 M5030 Hard Drive Replacement, Replace the Screws: passo 5, imagem 1 %32
    • Turn the computer over and replace the two screws that secure the hard- drive to the base of the computer.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.034 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 150
