Ir para o conteúdo principal
Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement
O que você precisa
  1. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement, M.2 NVMe Solid State Drive: passo 1, imagem 1 %32 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement, M.2 NVMe Solid State Drive: passo 1, imagem 2 %32
    • Place the laptop with the bottom panel facing up.
    • Remove the single screw to access the bottom panel.
  2. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 2, imagem 1 %32 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 2, imagem 2 %32 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 2, imagem 3 %32
    • Place a finger under the screw location and move it around the edge to pry the fourteen clips out.
    • There are six clips on each side of the panel and two on the edge by the screw.
    • Remove the bottom panel.
  3. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 3, imagem 1 %32 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 3, imagem 2 %32 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 3, imagem 3 %32
    • Locate the M.2 drive to the right of the battery, below the hard drive.
    • Remove the screw on the edge of the drive.
  4. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 4, imagem 1 %32 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 4, imagem 2 %32 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 4, imagem 3 %32
    • Lift up on the edge of the drive where the screw was.
    • Grab the drive by the two long edges.
    • Pull the drive out.
    • Note the keying on your new drive; it will only go in one way.
  5. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 5, imagem 1 %32 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 5, imagem 2 %32 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: passo 5, imagem 3 %32
    • Angle the new drive and insert it into the slot.
    • Apply pressure down on the screw end of the drive.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 36
Duração total: 3,082
