Ir para o conteúdo principal
Dell Inspiron 15 Gaming 7577 Hard Drive Replacement
O que você precisa
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • NOTE: The latch on the hard-drive locking connector is fragile. Pulling the latch forcefully may damage the hard-drive locking connector. Exercise care when handling the latch on the hard-drive locking connector.
  1. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Disconnecting the Hard Drive Cable: passo 2, imagem 1 %32
    • Open the latch and disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Peeling the Hard Drive Cable: passo 3, imagem 1 %32
    • Peel off the hard-drive cable from the computer base.
  3. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the four screws (M2.5x3) that secure the hard-drive assembly to the computer base.
  4. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Lifting the Hard-Drive Assembly: passo 5, imagem 1 %32
    • Lift the hard-drive assembly, along with its cable, off the computer base.
  5. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Disconnect the Inteposer: passo 6, imagem 1 %32
    • Disconnect the interposer from the hard-drive assembly.
  6. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Remove the Screws: passo 7, imagem 1 %32
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  7. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Lifting the Hard Drive Bracket: passo 8, imagem 1 %32
    • Lift the hard-drive bracket off the hard drive.
  8. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Align the Screw Holes: passo 9, imagem 1 %32
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  9. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Replace the Screws: passo 10, imagem 1 %32
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Connect the Interposer: passo 11, imagem 1 %32
    • Connect the interposer to the hard-drive assembly.
  11. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Align the Screw Holes: passo 12, imagem 1 %32
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  12. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Replace the Screws: passo 13, imagem 1 %32
    • Replace the four screws (M2.5x3) that secure the hard-drive assembly to the computer base.
  13. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Adhering the Hard Drive Cable: passo 14, imagem 1 %32
    • Adhere the hard-drive cable to the computer base.
  14. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Sliding the Hard Drive Cable: passo 15, imagem 1 %32
    • Slide the hard-drive cable into the connector on the system board and close the latch to secure the hard-drive cable.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.309 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.984 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 24
Duração total: 3,218
