Ir para o conteúdo principal
Dell Inspiron 15 Gaming 7577 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 15 Gaming 7577 Display Assembly Replacement, Remove the Screws: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the two screws (M2.5x5) that secure the display hinges to the palm-rest assembly.
  2. Dell Inspiron 15 Gaming 7577 Display Assembly Replacement, Open the Display Hinges: passo 2, imagem 1 %32
    • Open the display hinges at an angle of 90 degrees.
  3. Dell Inspiron 15 Gaming 7577 Display Assembly Replacement, Lifting the Palm-Rest Assembly: passo 3, imagem 1 %32
    • Lift the palm-rest assembly off the display assembly.
  4. Dell Inspiron 15 Gaming 7577 Display Assembly Replacement, Display Assembly: passo 4, imagem 1 %32
    • After performing the above steps, you will be left with the display assembly.
  5. Dell Inspiron 15 Gaming 7577 Display Assembly Replacement, Placing the Palm Rest: passo 5, imagem 1 %32
    • Place the palm-rest assembly on the display assembly.
  6. Dell Inspiron 15 Gaming 7577 Display Assembly Replacement, Close the Display Hinges: passo 6, imagem 1 %32
    • Close the display hinges at an angle of 90 degrees.
  7. Dell Inspiron 15 Gaming 7577 Display Assembly Replacement, Replace the Screws: passo 7, imagem 1 %32
    • Replace the two screws (M2.5x5) that secure the display hinges to the palm-rest assembly.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 1,972
