Ir para o conteúdo principal
Dell Inspiron 15 Gaming 7567 Memory Modules Replacement
  1. Dell Inspiron 15 Gaming 7567 Memory Modules Replacement, Popping up the Memory Module: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
  2. Dell Inspiron 15 Gaming 7567 Memory Modules Replacement, Remove the Memory Module: passo 2, imagem 1 %32
    • Remove the memory module from the memory-module slot.
  3. Dell Inspiron 15 Gaming 7567 Memory Modules Replacement, Align the Notch: passo 3, imagem 1 %32
    • Align the notch on the NEW memory module with the tab on the memory-module slot and slide it firmly into the slot at an angle.
  4. Dell Inspiron 15 Gaming 7567 Memory Modules Replacement, Press the Module Down: passo 4, imagem 1 %32
    • Press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.091 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 1,097
