Ir para o conteúdo principal
Dell Inspiron 15 Gaming 7567 Battery Replacement
O que você precisa
  1. Dell Inspiron 15 Gaming 7567 Battery Replacement, Remove the Battery Cable: passo 1, imagem 1 %32
  2. Dell Inspiron 15 Gaming 7567 Battery Replacement, Remove the Screws: passo 2, imagem 1 %32
    • Remove the five screws (M2x4 T8) that secure the battery to the computer base.
  3. Dell Inspiron 15 Gaming 7567 Battery Replacement, Lifting the Battery: passo 3, imagem 1 %32
    • Lift the battery at an angle off the computer base.
    • Turn the computer over, open the display, and press and hold the power button for five seconds to ground the system board.
  4. Dell Inspiron 15 Gaming 7567 Battery Replacement, Sliding the Battery: passo 5, imagem 1 %32
    • Slide the battery in the slot on the computer base and align the screw holes on the battery with the screw holes on the computer base.
  5. Dell Inspiron 15 Gaming 7567 Battery Replacement, Replace the Screws: passo 6, imagem 1 %32
    • Replace the five screws (M2x4 T8) that secure the battery to the computer base.
  6. Dell Inspiron 15 Gaming 7567 Battery Replacement, Routing the Battery Cable: passo 7, imagem 1 %32
    • Route the battery cable through the routing guides on the computer base.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
Um comentário
Dell UK do not sell a genuine battery replacement (part 71JF4). Where can a battery be purchased that will work, without running into the issue stated on the Dell forum that non-Dell batteries are not recognised and will not charge? Replacement batteries shown on Amazon and eBay provide no certainty that they are genuine or would otherwise work. Thanks!
Saskwoch - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 34
Duração total: 3,844
