Ir para o conteúdo principal
Dell Inspiron 15 7579 Wifi Card Replacement
O que você precisa
  1. Dell Inspiron 15 7579 Wifi Card Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Wifi Card Replacement: passo 2, imagem 1 %32 Dell Inspiron 15 7579 Wifi Card Replacement: passo 2, imagem 2 %32
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Wifi Card Replacement, Wifi Card: passo 3, imagem 1 %32
    • Remove the bracket holding the card in place by unscrewing the single 3 mm screw located in the upper left hand corner of the device using a Phillips #1 screwdriver bit.
  4. Dell Inspiron 15 7579 Wifi Card Replacement: passo 4, imagem 1 %32
    • Pull the Wi-Fi card out of the connector slot.
  5. Dell Inspiron 15 7579 Wifi Card Replacement: passo 5, imagem 1 %32
    • Remove the two connector pins from the wifi card using tweezers.
    • During reassembly, the pins require some finesse to fit them back onto the card. It will take time to put back on. Be sure to line up the socket on the cable to the pin socket on the card.
Conclusão
Inaki Madrigal
Membro desde: 04/23/18
730 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S24-G9, Maness Spring 2018 Membro de Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 22
Duração total: 3,745
