Ir para o conteúdo principal
Dell Inspiron 15 7579 Touchpad Replacement
O que você precisa
  1. Dell Inspiron 15 7579 Touchpad Replacement, Touchpad: passo 1, imagem 1 %32 Dell Inspiron 15 7579 Touchpad Replacement, Touchpad: passo 1, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the ten 8 mm securing the bottom panel.
    • Lift the bottom panel up and off of the chassis.
  2. Dell Inspiron 15 7579 Touchpad Replacement: passo 2, imagem 1 %32 Dell Inspiron 15 7579 Touchpad Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the four 3.7 mm screws securing the battery.
    • Lift the battery up and out.
  3. Dell Inspiron 15 7579 Touchpad Replacement: passo 3, imagem 1 %32 Dell Inspiron 15 7579 Touchpad Replacement: passo 3, imagem 2 %32 Dell Inspiron 15 7579 Touchpad Replacement: passo 3, imagem 3 %32
    • Use the tip of a spudger to flip up the locking bars on the five ZIF connectors, then pull the ribbon cables directly out of their ports.
    • Use a Phillips #0 screwdriver to remove the four 2.2 mm screws along the top of the touchpad.
    • One 2.2 mm screw is hidden under the cables at the top right corner of the touchpad.
    • Lift the trackpad up and out.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 345
