Ir para o conteúdo principal
Dell Inspiron 15 7579 RAM (Memory) Replacement
O que você precisa
  1. Dell Inspiron 15 7579 RAM (Memory) Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 2, imagem 1 %32 Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 2, imagem 2 %32
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 RAM (Memory) Replacement, RAM (Memory): passo 3, imagem 1 %32
    • Fold protective flaps to the side on the RAM module located in the upper right corner of the laptop.
  4. Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 4, imagem 1 %32 Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 4, imagem 2 %32 Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the tweezers to push the crimping metal away from the chip. The chip will pop up into an angled position.
    • Remove the chip by pulling at the same angle as the chip with the tweezers.
  5. Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 5, imagem 1 %32 Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 5, imagem 2 %32 Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 5, imagem 3 %32
    • Fold the plastic flap over on the other side.
    • As before, pull the fasteners away from the chip with the tweezers.
    • Remove the chip by carefully pulling it out with the tweezers.
  6. Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 6, imagem 1 %32 Dell Inspiron 15 7579 RAM (Memory) Replacement: passo 6, imagem 2 %32
    • When reassembling, you must match the notch in the card with the notch in the connector header shown in red.
    • Doing otherwise will break the stick if forced.
Conclusão
Inaki Madrigal
Membro desde: 04/23/18
760 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S24-G9, Maness Spring 2018 Membro de Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 711
