Introdução
Upgraded RAM can help your computer run smoother. Be cautious when following guide backwards.
  1. Remove the ten 7.9 mm screws with the Phillips #1 screwdriver.
    • Remove the ten 7.9 mm screws with the Phillips #1 screwdriver.
  2. Insert metal spudger into a gap in between the back panel and the back of the screen. Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Fold protective flaps to the side on the RAM module located in the upper right corner of the laptop.
    • Fold protective flaps to the side on the RAM module located in the upper right corner of the laptop.
  5. Use the tweezers to push the crimping metal away from the chip. The chip will pop up into an angled position. Remove the chip by pulling at the same angle as the chip with the tweezers. Remove the chip by pulling at the same angle as the chip with the tweezers.
    • Use the tweezers to push the crimping metal away from the chip. The chip will pop up into an angled position.
    • Remove the chip by pulling at the same angle as the chip with the tweezers.
  6. Fold the plastic flap over on the other side. As before, pull the fasteners away from the chip with the tweezers. Remove the chip by carefully pulling it out with the tweezers.
    • Fold the plastic flap over on the other side.
    • As before, pull the fasteners away from the chip with the tweezers.
    • Remove the chip by carefully pulling it out with the tweezers.
  7. When reassembling, you must match the notch in the card with the notch in the connector header shown in red. Doing otherwise will break the stick if forced.
    • When reassembling, you must match the notch in the card with the notch in the connector header shown in red.
      • Doing otherwise will break the stick if forced.
Conclusão
Inaki Madrigal
607 reputação
6 Guides authored
Equipe
Cal Poly, Team S24-G9, Maness Spring 2018 Membro de Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 Membros
6 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Todo: 141
