Ir para o conteúdo principal
Dell Inspiron 15 7579 2-in-1 Battery Replacement
O que você precisa
  1. Dell Inspiron 15 7579 2-in-1 Battery Replacement, Disconnect the Battery Cable: passo 1, imagem 1 %32
  2. Dell Inspiron 15 7579 2-in-1 Battery Replacement, Remove the Screws: passo 2, imagem 1 %32
    • Remove the screws that secure the battery to the palm-rest assembly.
  3. Dell Inspiron 15 7579 2-in-1 Battery Replacement, Lifting the Battery: passo 3, imagem 1 %32
    • Lift the battery along with the battery cable off the palm-rest assembly.
    • Press and hold the power button for 5 seconds to ground the system board.
  4. Dell Inspiron 15 7579 2-in-1 Battery Replacement, Align the Screw Holes: passo 5, imagem 1 %32
    • Align the screw holes on the NEW battery with the screw holes on the palm-rest assembly.
  5. Dell Inspiron 15 7579 2-in-1 Battery Replacement, Replace the Screws: passo 6, imagem 1 %32
    • Replace the screws that secure the battery to the palm-rest assembly.
  6. Dell Inspiron 15 7579 2-in-1 Battery Replacement, Connecting the Batter Cable: passo 7, imagem 1 %32
    • Connect the battery cable to the system board.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 1,512
