Ir para o conteúdo principal
Dell Inspiron 15 7560 Fan Replacement
O que você precisa
  1. Dell Inspiron 15 7560 Fan Replacement, Fan: passo 1, imagem 1 %32
    • Power off the laptop.
    • Place the laptop with the bottom facing upwards.
    • Remove eight 5 mm screws from the bottom of the laptop.
    • Loosen the three captive screws.
    • Use an iFixit opening tool to pry the bottom cover away from the laptop.
  2. Dell Inspiron 15 7560 Fan Replacement: passo 2, imagem 1 %32
    • Remove the two screws from the fan.
  3. Dell Inspiron 15 7560 Fan Replacement: passo 3, imagem 1 %32 Dell Inspiron 15 7560 Fan Replacement: passo 3, imagem 2 %32
    • Remove the black insulating tape from the fan connector.
    • Pinch the sides of the white fan connector with your thumb and index fingernail and pull it out of its socket.
    • Remove the fan from the laptop.
    • Save the insulating tape for reinstallation.
  4. Dell Inspiron 15 7560 Fan Replacement: passo 4, imagem 1 %32 Dell Inspiron 15 7560 Fan Replacement: passo 4, imagem 2 %32
    • Place the new fan in the laptop.
    • Plug the cable connector into its socket on the motherboard.
    • Replace the two screws around the fan.
  5. Dell Inspiron 15 7560 Fan Replacement: passo 5, imagem 1 %32
    • Before replacing the bottom cover, start the computer to check if the cooling fan is installed successfully.
  6. Dell Inspiron 15 7560 Fan Replacement: passo 6, imagem 1 %32
    • Power down the computer.
    • Reassemble the bottom cover.
Linha de Chegada
Kristen Gismondi
Membro desde: 11/12/14
82.317 Reputação
Autoria de 200 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.303 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 26
Duração total: 675
