Ir para o conteúdo principal
Dell Inspiron 15 7560 Battery Replacement
O que você precisa
  1. Dell Inspiron 15 7560 Battery Replacement, Disconnect the Battery Cable: passo 1, imagem 1 %32
  2. Dell Inspiron 15 7560 Battery Replacement, Peel the Tape: passo 2, imagem 1 %32
    • Peel the tape that secures the hard-drive cable to the battery.
  3. Dell Inspiron 15 7560 Battery Replacement, Open the Latch: passo 3, imagem 1 %32
    • Open the latch and disconnect the hard-drive cable from the system board.
  4. Dell Inspiron 15 7560 Battery Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
  5. Dell Inspiron 15 7560 Battery Replacement, Lifting the Battery: passo 5, imagem 1 %32
    • Lift the battery off the palm rest and keyboard assembly.
    • Press and hold the power button for five seconds to ground the system board.
  6. Dell Inspiron 15 7560 Battery Replacement, Align the Screw Holes: passo 7, imagem 1 %32
    • Align the screw holes on the NEW battery with the screw holes on the palm rest and keyboard assembly.
  7. Dell Inspiron 15 7560 Battery Replacement, Replace the Screws: passo 8, imagem 1 %32
    • Replace the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
  8. Dell Inspiron 15 7560 Battery Replacement, Sliding the Hard Drive Cable: passo 9, imagem 1 %32
    • Slide the hard-drive cable into the connector on the system board and close the latch to secure the cable.
  9. Dell Inspiron 15 7560 Battery Replacement, Adhering the Tape: passo 10, imagem 1 %32
    • Adhere the tape that secures the hard-drive cable to the battery.
  10. Dell Inspiron 15 7560 Battery Replacement, Connect the Battery Cable: passo 11, imagem 1 %32
    • Connect the battery cable to the system board.
Linha de Chegada
3 outras pessoas executaram este guia.
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 20
Duração total: 4,514
