Ir para o conteúdo principal
Dell Inspiron 15 5584 Battery Replacement
O que você precisa
  1. Dell Inspiron 15 5584 Battery Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Make sure to turn off and unplug your laptop before starting.
    • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
  2. Dell Inspiron 15 5584 Battery Replacement: passo 2, imagem 1 %32 Dell Inspiron 15 5584 Battery Replacement: passo 2, imagem 2 %32 Dell Inspiron 15 5584 Battery Replacement: passo 2, imagem 3 %32
    • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
    • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
    • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
  3. Dell Inspiron 15 5584 Battery Replacement: passo 3, imagem 1 %32 Dell Inspiron 15 5584 Battery Replacement: passo 3, imagem 2 %32
    • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
    • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
    • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
  4. Dell Inspiron 15 5584 Battery Replacement: passo 4, imagem 1 %32 Dell Inspiron 15 5584 Battery Replacement: passo 4, imagem 2 %32
    • Gently pry off the bottom cover from the laptop.
    • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
  5. Dell Inspiron 15 5584 Battery Replacement, Battery: passo 5, imagem 1 %32 Dell Inspiron 15 5584 Battery Replacement, Battery: passo 5, imagem 2 %32
    • Remove the four 3.5 mm screws holding the battery down with a JIS #0 screwdriver.
  6. Dell Inspiron 15 5584 Battery Replacement: passo 6, imagem 1 %32 Dell Inspiron 15 5584 Battery Replacement: passo 6, imagem 2 %32 Dell Inspiron 15 5584 Battery Replacement: passo 6, imagem 3 %32
    • Detach the motherboard connector tab from the top left of the battery.
    • Remove the battery from the device.
    • Be sure to carefully wiggle the connector out from the battery socket. Ripping it out too forcefully could damage the socket.
Conclusão
Uma outra pessoa concluiu este guia.
Sam Vorn
Membro desde: 03/29/22
977 Reputação
Autoria de 9 guias
Equipe
UMass Dartmouth, Team 1-1, Mellen Spring 2022 Membro de UMass Dartmouth, Team 1-1, Mellen Spring 2022
UMASSD-MELLEN-S22S1G1
Membros da 3
Autoria de 10 guias
Um comentário
I used this guide for a Dell Inspiron 5579 and it was close enough. The 5579 is larger. There were 10 screws instead of 9, and the back corner screws were removable. For the battery there were only the 2 left screws to remove as the 2 right battery mounts were also case-mounting screws. Was easy peazy. Now just need to charge it! Thanks!
John Highet - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 20
Últimos 30 dias: 66
Duração total: 2,911
