Ir para o conteúdo principal
Dell Inspiron 15 5578 2-in-1 Memory Module Replacement
  1. Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Lifting the Mylar: passo 1, imagem 1 %32
  2. Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Popping up the Memory Module: passo 2, imagem 1 %32 Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Popping up the Memory Module: passo 2, imagem 2 %32 Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Popping up the Memory Module: passo 2, imagem 3 %32
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
  3. Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Remove the Memory Module: passo 3, imagem 1 %32 Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Remove the Memory Module: passo 3, imagem 2 %32
    • Remove the memory module from the memory-module slot.
  4. Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Lifting the Mylar: passo 4, imagem 1 %32 Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Lifting the Mylar: passo 4, imagem 2 %32
    • Lift the Mylar to access the memory-module slot.
  5. Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Align the Notch: passo 5, imagem 1 %32 Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Align the Notch: passo 5, imagem 2 %32 Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Align the Notch: passo 5, imagem 3 %32
    • Align the notch on the memory module with the tab on the memory-module slot.
  6. Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Sliding the Memory Module: passo 6, imagem 1 %32
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.091 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 461
