Ir para o conteúdo principal
Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Disconnect the Hard Drive Cable: passo 1, imagem 1 %32 Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Disconnect the Hard Drive Cable: passo 1, imagem 2 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Using the pull tab, disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Peel off the Tape: passo 2, imagem 1 %32
    • Peel off the tape that secures the hard-drive cable to the palm rest and keyboard assembly.
  3. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Noting the Hard Drive Cable: passo 3, imagem 1 %32
    • Note the hard-drive cable routing and remove the cable from the routing guides.
  4. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
  5. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Lifting the Hard-Drive Assembly: passo 5, imagem 1 %32
    • Lift the hard-drive assembly along with its cable off the palm rest and keyboard assembly.
  6. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Disconnect the Interposer: passo 6, imagem 1 %32 Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Disconnect the Interposer: passo 6, imagem 2 %32
    • Disconnect the interposer from the hard-drive assembly.
  7. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Remove the Screws: passo 7, imagem 1 %32
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Lifting the Hard Drive: passo 8, imagem 1 %32 Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Lifting the Hard Drive: passo 8, imagem 2 %32
    • Lift the hard drive off the hard-drive bracket.
  9. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Align the Screw Holes: passo 9, imagem 1 %32
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  10. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Replace the Screws: passo 10, imagem 1 %32
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  11. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Connecting the Interposer: passo 11, imagem 1 %32
    • Connect the interposer to the hard-drive assembly.
  12. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Align the Screw Holes: passo 12, imagem 1 %32
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
  13. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Replace the Screws: passo 13, imagem 1 %32
    • Replace the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
  14. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Routing the Hard Drive Cable: passo 14, imagem 1 %32
    • Route the hard-drive cable through the routing guides on the palm rest and keyboard assembly.
  15. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Connect the Hard Drive Cable: passo 15, imagem 1 %32
    • Connect the hard-drive cable to the system board.
  16. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Adhering the Tape: passo 16, imagem 1 %32
    • Adhere the tape that secures the hard-drive cable to the palm rest and keyboard assembly.
Linha de Chegada
3 outras pessoas executaram este guia.
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,154
