Ir para o conteúdo principal
Dell Inspiron 15 5578 2-in-1 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 15 5578 2-in-1 Display Assembly Replacement, Open the Display: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Turn the computer over and open the display to 180-degree angle.
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
  2. Dell Inspiron 15 5578 2-in-1 Display Assembly Replacement, Placing the Computer Down: passo 2, imagem 1 %32
    • Place the computer on a flat surface with the display facing down.
  3. Dell Inspiron 15 5578 2-in-1 Display Assembly Replacement, Remove the Screws: passo 3, imagem 1 %32
    • Remove the screws that secure the display assembly to the palm rest and keyboard assembly.
  4. Dell Inspiron 15 5578 2-in-1 Display Assembly Replacement, Remove the Antenna Cables: passo 4, imagem 1 %32
    • Remove the antenna cables from the routing guide on the palm rest and keyboard assembly.
  5. Dell Inspiron 15 5578 2-in-1 Display Assembly Replacement, Lifting the Display Assembly: passo 5, imagem 1 %32
    • Lift the display assembly off the palm rest and keyboard assembly.
  6. Dell Inspiron 15 5578 2-in-1 Display Assembly Replacement, Align the Screw Holes: passo 6, imagem 1 %32
    • With the display facing down, align the screw holes on the display hinges with the screw holes on the palm rest and keyboard assembly.
  7. Dell Inspiron 15 5578 2-in-1 Display Assembly Replacement, Replace the Screws: passo 7, imagem 1 %32
    • Replace the screws that secure the display assembly to the palm rest and keyboard assembly.
    • Turn the computer over and close the display.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 1,873
