Ir para o conteúdo principal
Dell Inspiron 15 5577 Gaming Touch Pad Replacement
O que você precisa
  1. Dell Inspiron 15 5577 Gaming Touch Pad Replacement, Touch Pad: passo 1, imagem 1 %32
    • Flip the computer over so the bottom side is up, then unscrew the base cover.
  2. Dell Inspiron 15 5577 Gaming Touch Pad Replacement: passo 2, imagem 1 %32 Dell Inspiron 15 5577 Gaming Touch Pad Replacement: passo 2, imagem 2 %32
    • Flip the computer back over and open the lid before removing the shell.
  3. Dell Inspiron 15 5577 Gaming Touch Pad Replacement: passo 3, imagem 1 %32 Dell Inspiron 15 5577 Gaming Touch Pad Replacement: passo 3, imagem 2 %32 Dell Inspiron 15 5577 Gaming Touch Pad Replacement: passo 3, imagem 3 %32
    • Once the shell is removed, flip it and begin to pop out the touch pad.
Conclusão
Uma outra pessoa concluiu este guia.
Julia Cabral
Membro desde: 10/31/19
379 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S2-G7, Barthe Fall 2019 Membro de UMass Dartmouth, Team S2-G7, Barthe Fall 2019
UMASSD-BARTHE-F19S2G7
Membros da 2
Autoria de 2 guias
2 comentários
Does the touchpad not require a connection?
Senbi Stevens - Responder
WARNING! If you use this method, you will positively break your Dell 5577 laptop. The pictures of the laptop that are shown above must be from a laptop that was already broken. The tiny plastic rivets of the palmrest have plastic welds with the c-shell of the laptop. Therefore, you can certainly pull those rivets out by applying force but you cannot reattach them unless you use some kind of glue after performing this procedure. I followed this process. Now I have to replace my laptop’s C-shell. I don’t know what is the right process but the right process has to be from the bottom, NOT by taking out the palmrest and the top parts.
There is one more problem. If you use this process, it will be quite a pain to reattach the wire to the new touchpad, There is only a very tiny piece of the wire sticking out, which will be hard to reattach unless you apply force and pull out the wire. This is what I did.
If you are OK with reattaching the stuff with glue, you can use this process.
Rob - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 26
Duração total: 1,915
