Ir para o conteúdo principal
Dell Inspiron 15 5577 Gaming Hard-Drive Replacement
O que você precisa
  1. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement, Hard-Drive: passo 1, imagem 1 %32
    • Turn your Dell Inspiron laptop up side down to locate a screw at the top of the device.
    • Unscrew the back cover with your Phillips Head screwdriver.
  2. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: passo 2, imagem 1 %32
    • Remove the back cover. If you're having difficulty removing it, use a plastic opening tool, and pry the back cover away from the laptop.
  3. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: passo 3, imagem 1 %32
    • Unscrew all 4 screws located around the hard drive.
  4. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: passo 4, imagem 1 %32
    • Remove the cable above the hard drive. This can be done with a gentle tug perpendicular to the surface it is attached to.
  5. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: passo 5, imagem 1 %32
    • Remove the hard drive. If you're having difficulty removing it, use a plastic opening tool.
  6. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: passo 6, imagem 1 %32
    • Unscrew the four screws on the hard drive casing.
  7. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: passo 7, imagem 1 %32
    • Remove the hard drive casing. If you're having difficulty removing it, use a plastic opening tool.
Conclusão
[deleted]
Membro desde: 10/31/19
346 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 25
Últimos 30 dias: 30
Duração total: 810
