Ir para o conteúdo principal
Dell Inspiron 15 5577 Gaming Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Disconnect the Hard Drive Cable: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Using the pull-tab, disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Remove the Screws: passo 2, imagem 1 %32
    • Remove the four screws (M2x5) that secure the hard-drive assembly to the computer base.
  3. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Lifting the Hard Drive Assembly: passo 3, imagem 1 %32
    • Lift the hard-drive assembly, along with its cable, off the computer base.
  4. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Disconnecting the Interposer: passo 4, imagem 1 %32
    • Disconnect the interposer from the hard-drive assembly.
  5. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Remove the Screws: passo 5, imagem 1 %32
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Remove the Hard-Drive Bracket: passo 6, imagem 1 %32
    • Remove the hard-drive bracket off the hard drive.
  7. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Align the Screw Holes: passo 7, imagem 1 %32
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  8. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Replace the Screws: passo 8, imagem 1 %32
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  9. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Connect the Interposer: passo 9, imagem 1 %32
    • Connect the interposer to the hard-drive assembly.
  10. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Align the Screw Holes: passo 10, imagem 1 %32
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  11. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Replace the Screws: passo 11, imagem 1 %32
    • Replace the four screws (M2x5) that secure the hard-drive assembly to the computer base.
  12. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Connect the Hard Drive Cable: passo 12, imagem 1 %32
    • Connect the hard-drive cable to the connector on the system board.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 2,750
