Ir para o conteúdo principal
Dell Inspiron 15 5577 Gaming Battery Replacement
O que você precisa
  1. Dell Inspiron 15 5577 Gaming Battery Replacement, Remove the Battery Cable: passo 1, imagem 1 %32
  2. Dell Inspiron 15 5577 Gaming Battery Replacement, Remove the Screws: passo 2, imagem 1 %32
    • Remove the five screws (M2x5 T8) that secure the battery to the computer base.
  3. Dell Inspiron 15 5577 Gaming Battery Replacement, Lifting the Battery: passo 3, imagem 1 %32
    • Using the pull tab, lift the battery, along with its cable, off the computer base.
    • Turn the computer over, open the display, and press and hold the power button for five seconds to ground the system board.
  4. Dell Inspiron 15 5577 Gaming Battery Replacement, Sliding the Battery: passo 5, imagem 1 %32
    • Slide the NEW battery in the slot on the computer base.
  5. Dell Inspiron 15 5577 Gaming Battery Replacement, Align the Screw Holes: passo 6, imagem 1 %32
    • Align the screw holes on the battery with the screw holes on the computer base.
  6. Dell Inspiron 15 5577 Gaming Battery Replacement, Replace the Screws: passo 7, imagem 1 %32
    • Replace the five screws (M2x5 T8) that secure the battery to the computer base.
  7. Dell Inspiron 15 5577 Gaming Battery Replacement, Routing the Battery Cable: passo 8, imagem 1 %32
    • Route the battery cable through the routing guides on the computer base.
Linha de Chegada
3 outras pessoas executaram este guia.
Terrence15
Membro desde: 12/18/17
79.549 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 43
Autoria de 1.985 guias
Um comentário
Please include a screwdriver valid for the M2x5 T8 battery screws under tools. Thanks.
David Paul Hamilton - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 29
Duração total: 5,131
