Ir para o conteúdo principal
Dell Inspiron 15 5576 Gaming Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Disconnecting the Display Cable: passo 2, imagem 1 %32
    • Using the pull tab, disconnect the display cable from the system board.
  2. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Note the Display Cable: passo 3, imagem 1 %32
    • Note the display-cable routing and remove the cable from the routing guides on the computer base.
  3. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Disconnecting the Antenna Cables: passo 4, imagem 1 %32
    • Disconnect the antenna cables from the wireless card.
  4. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Note the Antenna Cable Routing: passo 5, imagem 1 %32
    • Note the antenna-cable routing and remove the antenna cables from the routing guides on the computer base.
  5. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Sliding the Display Cable: passo 6, imagem 1 %32
    • Slide the display cable and antenna cables through the slots on the computer base.
  6. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Remove the Screws: passo 7, imagem 1 %32
    • Remove the four screws (M2x5) that secure the display assembly to the computer base.
  7. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Lifting the Display Assembly: passo 8, imagem 1 %32
    • Lift the display assembly off the computer base.
  8. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Align the Screw Holes: passo 9, imagem 1 %32
    • Align the screw holes on the NEW display assembly with the screw holes on the computer base.
  9. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Replace the Screws: passo 10, imagem 1 %32
    • Replace the four screws (M2x5) that secure the display assembly to the computer base.
  10. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Sliding the Display Cable: passo 11, imagem 1 %32
    • Slide the display cable and antenna cables through the slot on the computer base.
  11. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Route the Display Cable: passo 12, imagem 1 %32
    • Close the display and turn the computer over.
    • Route the display cable and antenna cables through the routing guides on the computer base.
  12. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Connect the Antenna Cables: passo 13, imagem 1 %32
    • Connect the antenna cables to the wireless card.
  13. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Connecting the Display Cable: passo 14, imagem 1 %32
    • Connect the display cable to the system board.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 672
