Introdução
In this guide, we will be showing you how to remove and replace the Hard Drive.
O que você precisa
Lift the latch and using the pull tab disconnect the hard-drive cable from the system board.
Remove the four screws (M2.5x8) that secure the hard-drive assembly to the computer base.
Lift the hard-drive assembly out of the computer base using the hard-drive pull tab.
Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
Place the hard-drive assembly in the computer base and align the screw holes on the hard-drive assembly with the screw holes on the computer base.
Replace the four screws (M2.5x8) that secure the hard-drive assembly to the computer base.
Slide the hard-drive cable into the connector and press down on the latch to secure the cable to the system board.
