Ir para o conteúdo principal
Dell Inspiron 15 3593 Battery Replacement
O que você precisa
  1. Dell Inspiron 15 3593 Battery Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 15 3593 Battery Replacement, Battery: passo 1, imagem 2 %32
    • First, make sure the computer is turned off and unplugged.
    • Turn the computer upside down so its backside is facing you and place on a flat and clean surface to work.
    • Use a Phillips #0 screwdriver to remove six (M2.5x7mm) screws, three (M2x2mm) screws, and one (M2x4mm) screw.
    • Remove the optical drive.
  2. Dell Inspiron 15 3593 Battery Replacement: passo 2, imagem 1 %32 Dell Inspiron 15 3593 Battery Replacement: passo 2, imagem 2 %32
    • Turn the laptop over and open the lid so the screen faces you.
    • Use the plastic opening tool to gently pry the top panel with keyboard off of the computer. Work your way around the perimeter and undo the clips holding it down.
    • Don't use a butter knife like in the photo, as this could cause damage to the device.
  3. Dell Inspiron 15 3593 Battery Replacement: passo 3, imagem 1 %32 Dell Inspiron 15 3593 Battery Replacement: passo 3, imagem 2 %32 Dell Inspiron 15 3593 Battery Replacement: passo 3, imagem 3 %32
    • Close the lid and flip the laptop so the backside is facing up.
    • Pull the back panel off to reveal the battery.
  4. Dell Inspiron 15 3593 Battery Replacement: passo 4, imagem 1 %32 Dell Inspiron 15 3593 Battery Replacement: passo 4, imagem 2 %32
    • Disconnect the battery connector from the motherboard.
    • Use the Phillips #0 screwdriver to remove the four (M2x3mm) screws that are keeping the battery in place.
  5. Dell Inspiron 15 3593 Battery Replacement: passo 5, imagem 1 %32
    • Lift the battery out carefully and put the new battery in.
Conclusão
Reassemble the computer by following
the above steps in reversed order.
Abdul Obaid
Membro desde: 01/13/22
169 Reputação
Autoria de 1 guia
Equipe
2 comentários
not all of the steps
there is somethings missing
aaaa2020 - Responder
So where is the rest of the story?
Jeanette Martinez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 24
Últimos 30 dias: 90
Duração total: 2,792
