Ir para o conteúdo principal
Dell Inspiron 15 3568 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 15 3568 Display Assembly Replacement, Open the Display: passo 1, imagem 1 %32
  2. Dell Inspiron 15 3568 Display Assembly Replacement, Note the Antenna Cable: passo 2, imagem 1 %32
    • Note the antenna cable routing and remove the antenna cables from its routing guides on the computer base.
  3. Dell Inspiron 15 3568 Display Assembly Replacement, Remove the Cable: passo 3, imagem 1 %32
    • Note the display cable routing and remove the cable from its routing guides on the computer base.
  4. Dell Inspiron 15 3568 Display Assembly Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the screws that secure the display hinges to the computer base.
  5. Dell Inspiron 15 3568 Display Assembly Replacement, Lifting the Display Assembly: passo 5, imagem 1 %32
    • Carefully lift the display assembly off the computer base.
  6. Dell Inspiron 15 3568 Display Assembly Replacement, Align the Screw Holes: passo 6, imagem 1 %32
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  7. Dell Inspiron 15 3568 Display Assembly Replacement, Replace the Screws: passo 7, imagem 1 %32
    • Replace the screws that secure the display hinges to the computer base.
  8. Dell Inspiron 15 3568 Display Assembly Replacement, Route the Display Cable: passo 8, imagem 1 %32
    • Route the display cable through its routing guides on the computer base.
  9. Dell Inspiron 15 3568 Display Assembly Replacement, Routing the Antenna Cables: passo 9, imagem 1 %32
    • Route the antenna cables through its routing guides and slide the antenna cables through the slot on the computer base.
    • Close the display and turn the computer over.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 577
