Ir para o conteúdo principal
Dell Inspiron 15 3567 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 15 3567 Display Assembly Replacement, Remove the Screws: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the three screws (2.5x8) that secure the display hinges to the palm-rest assembly.
  2. Dell Inspiron 15 3567 Display Assembly Replacement, Open the Display Hinges: passo 2, imagem 1 %32
    • Open the display hinges to an angle of 90 degrees.
  3. Dell Inspiron 15 3567 Display Assembly Replacement, Peel the Tape: passo 3, imagem 1 %32
    • Peel the tape that secures the display cable to the palm-rest assembly.
  4. Dell Inspiron 15 3567 Display Assembly Replacement, Open the Latch: passo 4, imagem 1 %32
    • Open the latch and disconnect the display cable.
  5. Dell Inspiron 15 3567 Display Assembly Replacement, Note the Display Cable: passo 5, imagem 1 %32
    • Note the display cable routing and remove the display cable from the routing guides on the palm-rest assembly.
  6. Dell Inspiron 15 3567 Display Assembly Replacement, Note the Antenna Cable: passo 6, imagem 1 %32
    • Note the antenna cable routing and remove the cable from its routing guides on the palm-rest assembly.
  7. Dell Inspiron 15 3567 Display Assembly Replacement, Open the Palm Rest Assembly: passo 7, imagem 1 %32
    • Open the palm-rest assembly at an angle and slide it off the display assembly.
  8. Dell Inspiron 15 3567 Display Assembly Replacement, Placing the Display Assembly: passo 8, imagem 1 %32
    • Place the NEW display assembly on a clean, flat surface.
  9. Dell Inspiron 15 3567 Display Assembly Replacement, Placing the Palm-Rest Assembly: passo 9, imagem 1 %32
    • Place the palm-rest assembly on the display assembly.
  10. Dell Inspiron 15 3567 Display Assembly Replacement, Close the Display Hinges: passo 10, imagem 1 %32
    • Close the display hinges and align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  11. Dell Inspiron 15 3567 Display Assembly Replacement, Replace the Screws: passo 11, imagem 1 %32
    • Replace the three screws (2.5x8) that secure the display hinges to the palm-rest assembly.
  12. Dell Inspiron 15 3567 Display Assembly Replacement, Route the Antenna Cables: passo 12, imagem 1 %32
    • Route the antenna cables through the routing guides on the palm-rest assembly.
  13. Dell Inspiron 15 3567 Display Assembly Replacement, Connecting the Display Cable: passo 13, imagem 1 %32
    • Connect the display cable and close the latch to secure the cable.
  14. Dell Inspiron 15 3567 Display Assembly Replacement, Route the Display Cable: passo 14, imagem 1 %32
    • Route the display cable through the routing guides on the palm-rest assembly.
  15. Dell Inspiron 15 3567 Display Assembly Replacement, Adhere the Tape: passo 15, imagem 1 %32
    • Adhere the tape that secures the display cable to the palm-rest assembly.
    • Close the display and turn the computer over.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 39
Duração total: 2,764
