Introdução
In this guide, we will be showing you how to remove and replace the Display Assembly.
O que você precisa
Remove the three screws (2.5x8) that secure the display hinges to the palm-rest assembly.
Peel the tape that secures the display cable to the palm-rest assembly.
Note the display cable routing and remove the display cable from the routing guides on the palm-rest assembly.
Note the antenna cable routing and remove the cable from its routing guides on the palm-rest assembly.
Open the palm-rest assembly at an angle and slide it off the display assembly.
Place the NEW display assembly on a clean, flat surface.
Close the display hinges and align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
Replace the three screws (2.5x8) that secure the display hinges to the palm-rest assembly.
Route the antenna cables through the routing guides on the palm-rest assembly.
Connect the display cable and close the latch to secure the cable.
Route the display cable through the routing guides on the palm-rest assembly.
Adhere the tape that secures the display cable to the palm-rest assembly.
