Ir para o conteúdo principal
Dell Inspiron 15 3565 Memory Module Replacement
  1. Dell Inspiron 15 3565 Memory Module Replacement, Popping up the Memory Module: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  2. Dell Inspiron 15 3565 Memory Module Replacement, Removing the Memory Module: passo 2, imagem 1 %32
    • Slide and remove the memory module from the memory-module slot.
  3. Dell Inspiron 15 3565 Memory Module Replacement, Align the Notch: passo 3, imagem 1 %32
    • Align the notch on the memory module with the tab on the memory-module slot and slide it firmly into the slot at an angle.
  4. Dell Inspiron 15 3565 Memory Module Replacement, Installing the Memory Module: passo 4, imagem 1 %32
    • Press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 12/18/17
79.858 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
43 Membros
Autoria de 1.993 guias
1Comentário do guia
What Laptop is this for? I guess the disassembly must be somewhere else.
Don Minish - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Ao todo: 1,021
