Introdução
In this guide, we will be showing you how to remove and replace the Hard Drive.
Peças
Não são necessárias peças.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Open the latch and disconnect the hard-drive cable from the system board.
  2. Remove the four screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
    • Remove the four screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
  3. Lift the hard-drive assembly off the palm-rest assembly.
    • Lift the hard-drive assembly off the palm-rest assembly.
  4. Disconnect the interposer from the hard-drive assembly.
    • Disconnect the interposer from the hard-drive assembly.
  5. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  6. Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  7. Lift the hard drive off the hard-drive bracket.
    • Lift the hard drive off the hard-drive bracket.
  8. Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  9. Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  10. Connect the interposer to the hard drive.
    • Connect the interposer to the hard drive.
  11. Place the hard-drive assembly in the palm-rest assembly and align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly. Place the hard-drive assembly in the palm-rest assembly and align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly.
    • Place the hard-drive assembly in the palm-rest assembly and align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly.
  12. Replace the four screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
    • Replace the four screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
  13. Slide the hard-drive cable into its connector on the system board and close the latch to secure the cable.
    • Slide the hard-drive cable into its connector on the system board and close the latch to secure the cable.
Linha de Chegada
Terrence15
70.334 reputação
442 Guides authored
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
925 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 43
Todo: 350
