Ir para o conteúdo principal
Dell Inspiron 15 3559 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 15 3559 Hard Drive Replacement, Remove the Screws: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 15 3559 Hard Drive Replacement, Lifting the Latch: passo 2, imagem 1 %32 Dell Inspiron 15 3559 Hard Drive Replacement, Lifting the Latch: passo 2, imagem 2 %32
    • Lift the latch and disconnect the hard-drive cable from the system board.
  3. Dell Inspiron 15 3559 Hard Drive Replacement, Lifting the Hard-Drive Assembly: passo 3, imagem 1 %32
    • Lift the hard-drive assembly off the computer base.
  4. Dell Inspiron 15 3559 Hard Drive Replacement, Disconnecting the Interposer: passo 4, imagem 1 %32
    • Disconnect the interposer from the hard drive.
  5. Dell Inspiron 15 3559 Hard Drive Replacement, Remove the Screws: passo 5, imagem 1 %32
    • Remove the screws that secure the hard-drive bracket to the hard drive and lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 15 3559 Hard Drive Replacement, Placing the Hard Drive: passo 6, imagem 1 %32 Dell Inspiron 15 3559 Hard Drive Replacement, Placing the Hard Drive: passo 6, imagem 2 %32
    • Place the hard-drive bracket over the NEW hard drive and align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  7. Dell Inspiron 15 3559 Hard Drive Replacement, Replace the Screws: passo 7, imagem 1 %32
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15 3559 Hard Drive Replacement, Sliding the Hard-Drive Assembly: passo 8, imagem 1 %32 Dell Inspiron 15 3559 Hard Drive Replacement, Sliding the Hard-Drive Assembly: passo 8, imagem 2 %32
    • Slide the hard-drive assembly in the computer base and align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  9. Dell Inspiron 15 3559 Hard Drive Replacement, Replace the Screws: passo 9, imagem 1 %32
    • Replace the screws that secure the hard-drive assembly to the computer base.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 12/18/17
79.131 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.986 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 1,109
