Introdução
You will be able to replace the entire screen assembly after using this guide.
O que você precisa
Close the laptop and place it so that the back of the screen is lying flat on your work surface.
Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
Using a PH0 sized screw driver, carefully remove the 4mm screw from the bottom cover.
Using the plastic opening tool carefully pry open the bottom cover
Slide the bottom cover towards you and remove it from the laptop base. Put the cover aside.
Remove the 5mm long Phillips #0 screw that is holding the optical drive in place, as pictured.
You can now slide the optical disk drive out of the computer.
Open the laptop and fully extend the screen.
Using the nylon spudger, pry the keyboard off the laptop body.
Using your hands, remove the keyboard from the body and place it facedown on the track pad. There will be a cord connecting the laptop and the keyboard: keep this cord intact.
Remove the three 4mm PH0 phillips screws holding the palm rest cover.
Carefully disconnect all of the connectors with the blue tabs
Remove the 10 PH0 Phillips screws that secure the palm rest to the computer base. 8 of which are 6mm long.
Using a spudger, pry along the edge of the palm rest to begin removing it.
The palm rest is held in with plastic clips all of the way around, so you will have to carefully pry all the way around it.
Turn the computer back over and open the display as far as possible.
Lift up and towards the left to carefully remove the palm rest and reveal the motherboard.
Move the antenna cables through the slot on the computer base, and move them off to the side of the computer.
Peel off the tape that secures the display cable to the system board.
Lift the connector latch and disconnect the display cable from the system board.
8 outras pessoas executaram este guia.
