Ir para o conteúdo principal
Dell Inspiron 15 3541 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 15 3541 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 15 3541 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 3541 Keyboard Replacement: passo 2, imagem 1 %32
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 3541 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 Dell Inspiron 15 3541 Keyboard Replacement, Keyboard: passo 3, imagem 2 %32
    • Open the laptop and fully extend the screen.
    • Using the nylon spudger, pry the keyboard off the laptop body.
    • Using your hands, remove the keyboard from the body and place it facedown on the track pad. There will be a cord connecting the laptop and the keyboard: keep this cord intact.
  4. Dell Inspiron 15 3541 Keyboard Replacement: passo 4, imagem 1 %32 Dell Inspiron 15 3541 Keyboard Replacement: passo 4, imagem 2 %32
    • Unhook the connector and you can now remove the keyboard from the laptop
    • If your version of this laptop has a backlit keyboard, there will be two connectors; the one highlighted orange will also have to be removed.
Conclusão
8 outras pessoas executaram este guia.
Allison
Membro desde: 03/04/16
562 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 5-8, Landers Spring 2016 Membro de UMass Dartmouth, Team 5-8, Landers Spring 2016
UMASSD-LANDERS-S16S5G8
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 33
Duração total: 3,398
