Ir para o conteúdo principal
Dell Inspiron 15 3541 Battery Replacement
  1. Dell Inspiron 15 3541 Battery Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 15 3541 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 3541 Battery Replacement: passo 2, imagem 1 %32
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
Conclusão
3 outras pessoas executaram este guia.
Allison
Membro desde: 03/04/16
562 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 5-8, Landers Spring 2016 Membro de UMass Dartmouth, Team 5-8, Landers Spring 2016
UMASSD-LANDERS-S16S5G8
Membros da 3
Autoria de 6 guias
2 comentários
Can you do a guide on how to change a CPU on this computer?
F0RS3 Topaz - Responder
During this, the locks in side of this gets dispalced from there places so battery is not locking now. How to repair those locks?.
Vivek Goyenka - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 1,758
