Ir para o conteúdo principal
Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement
O que você precisa
  1. Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement, Battery removal: passo 1, imagem 1 %32
    • Turn the laptop over and unlock the battery by sliding the two locking tabs away from each other. The one on the left is spring loaded. Slide the battery out.
    • Simply slide the battery out in the direction shown.
  2. Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement, RAM removal: passo 2, imagem 1 %32 Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement, RAM removal: passo 2, imagem 2 %32
    • Undo the locking screw on RAM cover, then prise open the cover.
    • Release the RAM module or modules by pushing the metal clips outwards. Put the modules aside.
    • On reinserting the RAM modules, ensure that they are fully home in their sockets before angling them downwards to engage the clips.
  3. Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement, Bottom screws: passo 3, imagem 1 %32 Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement, Bottom screws: passo 3, imagem 2 %32
    • Note: if the laptop you are working on is a very slightly different model it is possible that it will have a different number of screws in slightly different positions. The important thing is to note where the shorter screws come from so as to avoid inserting a longer screw in its place on reassembly.
    • Remove a 5mm screw to the left of the RAM sockets, then pull out the CD/DVD drive. (Not necessary if you are only replacing the keyboard.)
    • Remove a 5mm screw to the right and the rear of the RAM sockets.
    • If you are going to remove the hard disk, motherboard or fan, remove 4 3mm screws.
    • Remove 7 5mm screws. (There are 6 more at the rear which should be left.)
  4. Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement: passo 4, imagem 1 %32 Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement: passo 4, imagem 2 %32
    • With a thin metal spudger you should now be able to release 4 clips along the top of the keyboard in order to lift it out.
    • If you find one or more of the tabs refuse to release, do not force it. You probably missed one (or more) of the screws in the bottom.
    • Lift the keyboard slightly from the back, disengaging its tabs along the front panel at the front. Turn it over towards you, taking care not to strain the ribbon.
    • Gently lift the locking bar on the ribbon socket and withdraw the ribbon. Put the keyboard aside.
Conclusão
Philip Le Riche
Membro desde: 02/18/14
30.083 Reputação
Autoria de 47 guias
Equipe
Restart Project Membro de Restart Project
Community
Membros da 18
Autoria de 493 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 730
