Ir para o conteúdo principal
Dell Inspiron 14z-5423 Motherboard Replacement
O que você precisa
  1. Dell Inspiron 14z-5423 Motherboard Replacement, RAM: passo 1, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement, RAM: passo 1, imagem 2 %32
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Motherboard Replacement: passo 2, imagem 1 %32
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Motherboard Replacement: passo 3, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement: passo 3, imagem 2 %32
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Motherboard Replacement: passo 4, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement: passo 4, imagem 2 %32
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Motherboard Replacement: passo 5, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement: passo 5, imagem 2 %32
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Motherboard Replacement, Optical Drive: passo 6, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement, Optical Drive: passo 6, imagem 2 %32
    • Slide the CD/DVD drive on the side of the laptop out using your fingers.
    • Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
    • You only need to unscrew this screw if you are using this as a prerequisite guide.
  7. Dell Inspiron 14z-5423 Motherboard Replacement, Keyboard: passo 7, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement, Keyboard: passo 7, imagem 2 %32 Dell Inspiron 14z-5423 Motherboard Replacement, Keyboard: passo 7, imagem 3 %32
    • Lift the plastic yellow flap on the system board.
    • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
  8. Dell Inspiron 14z-5423 Motherboard Replacement: passo 8, imagem 1 %32
    • Flip over the computer and open the display.
  9. Dell Inspiron 14z-5423 Motherboard Replacement: passo 9, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement: passo 9, imagem 2 %32
    • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
    • Lift the keyboard off of the computer.
    • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
  10. Dell Inspiron 14z-5423 Motherboard Replacement: passo 10, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement: passo 10, imagem 2 %32
    • Flip the keyboard over onto the palm-rest assembly.
  11. Dell Inspiron 14z-5423 Motherboard Replacement: passo 11, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement: passo 11, imagem 2 %32 Dell Inspiron 14z-5423 Motherboard Replacement: passo 11, imagem 3 %32
    • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
  12. Dell Inspiron 14z-5423 Motherboard Replacement, Palm Rest Assembly: passo 12, imagem 1 %32
  13. Dell Inspiron 14z-5423 Motherboard Replacement: passo 13, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement: passo 13, imagem 2 %32 Dell Inspiron 14z-5423 Motherboard Replacement: passo 13, imagem 3 %32
    • Remove all 7 rubber screw caps with tweezers.
    • Use a J0 Bit tipped screwdriver unscrew the seven 6 mm Phillips screws on the back casing of the laptop.
  14. Dell Inspiron 14z-5423 Motherboard Replacement: passo 14, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement: passo 14, imagem 2 %32
    • Flip the computer over and open the display.
    • Pull on the blue tabs to disconnect the palm rest assembly from the computer.
  15. Dell Inspiron 14z-5423 Motherboard Replacement: passo 15, imagem 1 %32
    • Use J0 Bit screwdriver to remove all four 6 mm Phillips screws.
  16. Dell Inspiron 14z-5423 Motherboard Replacement: passo 16, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement: passo 16, imagem 2 %32 Dell Inspiron 14z-5423 Motherboard Replacement: passo 16, imagem 3 %32
    • Gently wedge the nylon spudger underneath the palm-rest assembly to release the latches.
    • Continue this process on all sides of the computer edges until the assembly pulls off.
    • Remove the palm rest assembly.
    • If you have difficulty lifting up the assembly, you might not have taken out all 7 screws on the bottom of the computer.
  17. Dell Inspiron 14z-5423 Motherboard Replacement, Battery: passo 17, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement, Battery: passo 17, imagem 2 %32
    • Use a J0 Bit screwdriver to remove the two 6 mm Phillips screws securing the battery located near the bottom of the laptop.
  18. Dell Inspiron 14z-5423 Motherboard Replacement: passo 18, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement: passo 18, imagem 2 %32 Dell Inspiron 14z-5423 Motherboard Replacement: passo 18, imagem 3 %32
    • Lift the tiny black tab and pull the battery out at a slight angle.
  19. Dell Inspiron 14z-5423 Motherboard Replacement, Hard Drive: passo 19, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement, Hard Drive: passo 19, imagem 2 %32
    • Lift up the bottom of the hard drive which is located at the bottom of the laptop.
    • Gently pull the drive out at an angle using your fingers.
  20. Dell Inspiron 14z-5423 Motherboard Replacement: passo 20, imagem 1 %32
    • Using a J0 bit tipped screwdriver, remove the four 3 mm black screws on both sides of the hard drive bracket.
  21. Dell Inspiron 14z-5423 Motherboard Replacement: passo 21, imagem 1 %32
    • Slide the hard drive out of the bracket.
  22. Dell Inspiron 14z-5423 Motherboard Replacement, Wireless Mini Card: passo 22, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement, Wireless Mini Card: passo 22, imagem 2 %32
    • Locate the wireless mini card at the top of the laptop.
    • It is next to the place where the optics drive used to be.
  23. Dell Inspiron 14z-5423 Motherboard Replacement: passo 23, imagem 1 %32
    • Using a J0 tipped screwdriver, remove the 4 mm Phillips head screw.
  24. Dell Inspiron 14z-5423 Motherboard Replacement: passo 24, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement: passo 24, imagem 2 %32
    • Gently, unlatch the black and white wires from the wireless mini card.
  25. Dell Inspiron 14z-5423 Motherboard Replacement: passo 25, imagem 1 %32
    • At an angle, slide out the wireless mini card.
  26. Dell Inspiron 14z-5423 Motherboard Replacement, Motherboard: passo 26, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement, Motherboard: passo 26, imagem 2 %32
    • Gently pull the the blue ribbon upwards to disconnect the computer from the motherboard.
  27. Dell Inspiron 14z-5423 Motherboard Replacement: passo 27, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement: passo 27, imagem 2 %32
    • Using a plastic opening tool, gently detach the coin cell battery from the foam glue.
    • The coin cell battery is underneath the optical drive.
  28. Dell Inspiron 14z-5423 Motherboard Replacement: passo 28, imagem 1 %32 Dell Inspiron 14z-5423 Motherboard Replacement: passo 28, imagem 2 %32
    • Using a J0 tipped screwdriver remove the 6 mm Phillips head screw located at the center of the laptop on the motherboard.
  29. Dell Inspiron 14z-5423 Motherboard Replacement: passo 29, imagem 1 %32
    • Remove motherboard at an upward angle.
    • The coin cell battery and fan will be removed with the motherboard.
Conclusão
Marisol
Membro desde: 09/12/16
623 Reputação
Autoria de 4 guias
Equipe
CSU Fullerton, Team 2-2, Bruce Fall 2016 Membro de CSU Fullerton, Team 2-2, Bruce Fall 2016
CSUF-BRUCE-F16S2G2
Membros da 5
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 2,533
