Introdução
In this guide, we will be showing you how to remove and replace the Hard Drive Assembly.
O que você precisa
Remove the four screws that secure the hard-drive assembly to the computer base.
Using the pull-tab, slide the hard-drive assembly to disconnect it from the connector on the system board.
Remove the four screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
Replace the four screws that secure the hard-drive bracket to the hard drive.
Using the pull-tab, slide the hard-drive assembly into the connector on the system board.
Replace the four screws that secure the hard-drive assembly to the computer base.
