Ir para o conteúdo principal
Dell Inspiron 14z 1470 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 14z 1470 Hard Drive Replacement, Disconnecting the Audio Cable: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • Disconnect the USB/audio cable from the system board.
  2. Dell Inspiron 14z 1470 Hard Drive Replacement, Remove the Screws: passo 2, imagem 1 %32
    • Remove the four screws that secure the hard drive assembly to the computer base.
  3. Dell Inspiron 14z 1470 Hard Drive Replacement, Lifting the Hard Drive Assembly: passo 3, imagem 1 %32
    • Slide and lift the hard drive assembly out of the computer base.
  4. Dell Inspiron 14z 1470 Hard Drive Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the four screws that secure the hard drive to the hard drive bracket.
  5. Dell Inspiron 14z 1470 Hard Drive Replacement, Remove the Hard Drive: passo 5, imagem 1 %32
    • Remove the hard drive.
  6. Dell Inspiron 14z 1470 Hard Drive Replacement, Placing the Hard Drive: passo 6, imagem 1 %32
    • Place the NEW hard drive in the hard drive bracket and replace the four screws that secure the hard drive bracket to the hard drive.
  7. Dell Inspiron 14z 1470 Hard Drive Replacement, Sliding the Hard Drive: passo 7, imagem 1 %32
    • Slide the hard drive assembly into the computer base until it is fully seated.
  8. Dell Inspiron 14z 1470 Hard Drive Replacement, Replace the Screws: passo 8, imagem 1 %32
    • Replace the four screws that secure the hard drive assembly to the computer base.
  9. Dell Inspiron 14z 1470 Hard Drive Replacement, Connecting the Cable: passo 9, imagem 1 %32
    • Connect the USB/audio cable to the USB/audio board.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 995
