Ir para o conteúdo principal
Dell Inspiron 14R-5421 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 14R-5421 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Push the two sliders away from the battery towards the outer edges.
  2. Dell Inspiron 14R-5421 Keyboard Replacement: passo 2, imagem 1 %32 Dell Inspiron 14R-5421 Keyboard Replacement: passo 2, imagem 2 %32
    • Remove the battery when it pops up.
  3. Dell Inspiron 14R-5421 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Find the clips on the keyboard. They are shown by red arrows.
  4. Dell Inspiron 14R-5421 Keyboard Replacement: passo 4, imagem 1 %32
    • Using a pry tool, detach the 9 clips from the keyboard by prying at a 90 degree angle.
    • Be careful while detaching and do not lift the keyboard too high or be too rough. The keys can break easily and there is a fragile ribbon cable beneath the keyboard.
  5. Dell Inspiron 14R-5421 Keyboard Replacement: passo 5, imagem 1 %32
    • Carefully disconnect the ribbon cable from the socket and pull apart.
    • The cable could be connected to other components of the laptop. Proceed with caution because the cable is fragile.
Conclusão
Jared paiva
Membro desde: 03/27/18
489 Reputação
5 Guias de autoria
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 452
